scar
- Jan 25, 2006
How do I change my chaincase oil on my 99 vmax>Thanks
There is a drain plug on the inside of the tunnle on that side 10MM
SpartaSXr
or just pull the cover off and get all the metal shavings out.
sxviper32
SpartaSXr said:or just pull the cover off and get all the metal shavings out.
no, your better off using the plug. easier to do, less of a mess, and plus you shouldn't have metal shavings in there (sign of a problem) also the "dipstick" has the magnet on it to collect any metal shavings. just use the drain plug on the inside of the tunnel.
SpartaSXr
so if you shouldnt have metal shavings what's the magnet for? it is inevitable that the chain and gears wear. and yes it is cleaner to pull the plug.
flying dutchman
If you do want to pull the cover to check things out here's an idea to limit the mess. Take a look at your belly pan. There is a "bowl" indentation just below the chaincase.
Drill a hole in the bottom of this bowl. Tilt your sled just a bit.
Now when you loosen the cover the oil drains into this bowl, out the hole right into a catch basin. No mess in the bottom of your belly pan.
TJ500
why not pull the drain plug and drain oil first and then pull case cover off for an inspection after? never hurts to take cover off and do an inspection...
flying dutchman
TJ..........that's the best idea yet...........
And just for trivia, I have only owned my Yami for 7 years and never knew there was a drain plug on the inside until this season
I still can't figure out where it is.. so don't feel bad!!
maxout01 said:I still can't figure out where it is.. so don't feel bad!!
Get down on your hands and knees(may have to lay down) and look inside
the tunnle on the side. throttle side of course it's a 10mm bolt.........
TJ500
bottom of case, on inside of tunnel, pointing toward the track
ok, thank you!
It only has 65 miles on it since it was changed last year! got no snow all winter... I' ll do it in the summer some time!!
maxout01 said:It only has 65 miles on it since it was changed last year! got no snow all winter... I' ll do it in the summer some time!!
Thats right you hardly got any miles in..
Well, I didn't get to use it all winter really. So I decided to build it a new garage so I can make it nicer for next winter!!
yup makes it nice when you got to do some wrenching......
I got alot of work still on the garage too!! it's gonna be along summer!
