UPoutdoorzman
Going to summerize the sleds this weekend. Can anyone tell me how to best remove the airbox (or whatever it takes to gain better access to the carb throats) from a '99 Venture 700 triple? Seems like an all day task given the way cables and hoses are attached to the thing. Pictures would help greatly too. Thanks all!
take the philips screws out of the top, There are like 8 or so and slide the top of the box off and remove the shelf in the airbox. Should take about 5 minutes.
braindead1684
why are you taking it off, to fog it, or to leave off for the summer? if your just doing it to fog it you may be able to shoot the spray into the air box towards each carb, thats how i do it on my vmax, if your taking it off its easier to seperate it first as was mentioned above, then pull the bottom off if you want that out too.
98srx6
the airbox top comes off before the bottom half. Just start taking it apart....you will see how it goes. Its easy.
Here is a link to the section of the tech pages that focuses on summerizing your sled. Enjoy.
http://www.totallyamaha.com/snowmobiles/aaTECH/misc/summerstorage.htm
Or do a serch on "fogging" lots of info on this subject..
UPoutdoorzman
Thanks all! Braindead, you are right - that is what I did last year. I remember it being a very tight fit to get my hands and the spray can between the two halves and not being able to see if I am getting a good spray into the carbs with the fogging oil. I did not think about dropping the bottom half off and out of the way.
Rob
Rob
98srx6
outdoorzman, where in the UP are you from?
take the top off and the center shelf and its gravy from there. no need to remove the bottom from the carbs.
yamaholic22
yes if you are just fogging you don't need to remove the bottom half, just pull the shelf out and you have easy access to the throats.
