n2oiroc
the front protectors are welded top and bottom. i wouldnt try cutting the top welds. cut the bottom welds, stick a screwdriver in the protector and wiggle it until the upper weld breaks. it will break a lot cleaner than you could ever cut it.
tagoes10s
I have a extra set of 8" used drivers if anyone is interested $50 + shipping.
Dan
Dan
ExpertXViper
n2oiroc said:the front protectors are welded top and bottom. i wouldnt try cutting the top welds. cut the bottom welds, stick a screwdriver in the protector and wiggle it until the upper weld breaks. it will break a lot cleaner than you could ever cut it.
Thanks for the tip.
yamaham
8" Driver
What would shipping be to Cambridge, Ontario N3H 4R7? I'll take it if shipping is reasonable.
Thanks...Mike
Hi Dan,tagoes10s said:I have a extra set of 8" used drivers if anyone is interested $50 + shipping.
Dan
Thanks...Mike
why not just put 1.075" studs?
n2oiroc
with a 1.25" track? that wouldnt even make it flush with the lugs.jminor1 said:why not just put 1.075" studs?
n2oiroc
air cooled viper?yamaholic22 said:Technically i think they will clear the exchanger, but the clearance will be way too tight for comfort. Personally i would NOT stud a 1.25 inch track in a yamaha proaction chassis without going to 8 tooth drivers, not worth the risk. A torn up heat exchanger will end your day up north in a real hurry.
yamaholic22
n2oiroc said:air cooled viper?
hey it could work, just need something other than the water pump to pump the air around
n2oiroc said:with a 1.25" track? that wouldnt even make it flush with the lugs.
it is a staggered paddle and lugs flex more than studs do. Also, I meant 1.175 which gets you closer.
yamaholic22
even if you factor in a little amount of lug flex, the studs wont do much if anything if they dont protrude past the lugs at least 1/4"
I do agree with you I just wonder if they would give you a little help with traction on ice.
yamaholic22
honestly i think that if you wanted the small amount of traction addition that studs barely protruding would afford you, you would be better of with an ice claw or ice ripper with all those little lug studs. Not going to win you any drag races, but the added safety of studs is there for stopping and to prevent excess slide-out.
Faceman
I have an 04 Viper S and went through this mess last winter. I used hockey sticks for tunnel protectors (works great) and got front exchanger protectors from an 02 that fit very tight but fine. Am running a 1.25 ripsaw with the 1.35 studs....It works fine. Put 3000k on it last winter with no problems and not one scuff.
yamaham
Hi Faceman, Does the Viper S have the 8" driver or did you change to them? I have 8" drivers on the way but would rather not go through the work of changing it if I no not need.
Faceman
Studding
Yamaham. I'm not sure. It is the stock setup. This whole saga went round and round last year b4 I finally studded the track. There wasn't a listing for front tunnel protectors for an 04 and I believe the protectors are for an 02 SRX. It's amazing the information/mis-information out there. I talked to 5 different dealers/ service managers and got 5 different opinions. That shouldn't happen. All said and done, I'll never go back to clean track.
Faceman
Faceman
yamaham
Faceman, I am getting the same, talked to a couple stud mfgers at the Sled show last weekend, some said no problem the way it is(there buddys did it) others said I need smaller driver. I would like to take the easy way out, however usally the easy way ends up being the rough road.......
blueblooded
I didnt feel like screwing around with 8" drivers and the gear change so i just bought a 1" 9830 track and added 144 1.125 extreme max studs with srx heat exchangers-worked great.
