ExpertXViper
Gunna be running SLPs on my Viper. Just curious if SLPs jetting specs are kinda lean on the pilot and mains, or are the specs on the rich side. I'm still gunna monitor the plug and piston wash. But just wondering if I'm safer running a lil more rich to start. Let know if the specs are safe to start from and what kinda temps can there jetting specs hold up to. Thanks
SLP Specs:
162.5 Mains
47.5 Pilots
2 1/2 Turns on Fuel Screw
3 1/2 on Needle Jetting
All jetting is straight across and is for 0-2000 feet sea level.
SLP Specs:
162.5 Mains
47.5 Pilots
yamahajunkie
thats what i'm running
also thin head gasket
also thin head gasketMtnviper
I've found they're specs to be very close, to slightly rich. So if you start with they're spec's, you should be safe.
A K MtnViper
Down load slp's specs for clutching also, the extra hp's will require adjustments in clutching. Ride it first to get the feel of what clutch changes needs to be done.
ExpertXViper
I'm starting out with Maxx. Perf. Clutch kit made for these pipes. But if I feel that set-up isnt to my liking, I already have most of the parts for a diff. set-up that Skidooboy gave me. Thanks for your .02 fellas
red devil
HEY! IS THAT THE HDN-20 SETUP? I always wanted to try it and was wondering if can give me that setup and also what elevation you normally run and do you have a short track with the original track?? thanxs because I was going to throw something in it this year and it would be great to get it close, thats if skidooboy doesnt mind.
taped throttle
X, just some info for you on that kit, in case your not aware of the update. Maxx changed their original kit, which used stock 8EKs to diff ones, not sure what they are. i havent tried the newer kit, but if your planning on using the 8EK setup, its not that good. consider ski's if it includes 8DNs.
ExpertXViper
The newer kit uses 8BF weights with 4.5gm inner and 3.6gm outer. I'm switching those out for the DN8-20 . Reason I'm running with these is if you find a chart on these weights the B8F takes a dip in force unlike the DN's its a gradual climb.
skidooboy
red devil pm me, i will help you out. ski
taped throttle
k, just wanted to make sure you werent wasting your time on the old setup.
what helix are you using?
red devil
Thanx ski, I PMed you if I don't get back to you for awhile its because it's a busy time of year for me but I do appreciate your time as well as others.The jetting specs were good for me with slp setup I think I went on the safe side with the needle for mid range and backing off of a hard run.Don't worry about fuel mileage it was ok for what you gained, no srx from what is written on here but not that bad with other sleds from that year in my opinion.
