Mounting Skid Plate - Ok to drill into belly?
Morley
Canada - Above you
I need to mount a skid plate on my SXR and just want to know if it's all good
just to drill where the holes are pre-placed on the plastic skid plate into the belly pan of the sled? Should I use Rivets? or Bolts? I think bolts will be a mofo to get in there though.
I put a floor jack under the plate to hold it up TIGHT, and drill at a slight angle,so the bolts pull the skid plate up tight. had @ 1/8 gap on top on the first one I did looked poor!
I used SS self tapping screws about a 1/2" on the bottom & SS bolts for the front!
The only problem with bolts is that they stick out a bit and whill catch on rocks and sticks instead of slidding over them, unless u only trail ride.
