Crank lubrication?
dnale
South Lyon, Michigan
How does the crank and it's bearings get lube? I'm about to put every thing back together and the question just came to me. It's not like a car where we have a sump and pump. Sure we have an oil pump but thats for the injection. The chain case has it's own lube.
Just wondering....
the air/fuel/oil mix goes through the crankcase and lubes the crank bearings. some sleds have an oil line that feeds the injection oil directly to the bearings.
2 cycle oil
I used a dental syringe and injected 2-cycle oil on all the main bearings, rod bearings and piston needle bearings...just enough to have a small drip...don't forget to lube up the rings as you install them on the pistons...depending on your build, I lubed (about 1oz) the gear in the base case that drive the water/oil pumps...and of course you already know this pre-mix 6 gal of gas with 1 qt oil in jerry can and poor into a (already empty sled tank) add fresh oil to you oil tank and start her up...run the 6 gal through her and then it should be good to go- your oil tank should have drop a little indicating that the oiling system is bled out and everything is working well...Put in a new set of plugs and fill her up with fresh fuel...keep the smile on your face..hope this helped
