terret725
any one have the center to center mesaurment for one of the clutch tools that slips over the shaftss u can tighten the motor in teh right place. ive been a horible time getting my cluthc to sto squeeling sence i put the new belt on. its rubbing on the primary shaft and the cogs of the belt. i wanna cut out one of these tools so i can get it right.m id by one but i dont have a 120 bucks.
kysledneck
terret725 said:any one have the center to center mesaurment for one of the clutch tools that slips over the shaftss u can tighten the motor in teh right place. ive been a horible time getting my cluthc to sto squeeling sence i put the new belt on. its rubbing on the primary shaft and the cogs of the belt. i wanna cut out one of these tools so i can get it right.m id by one but i dont have a 120 bucks.[
You problem is not center to center it is offset! Mine squeeked like rat! loosened up the mounts got the motor moved within spec no mo squeek!
FuzzButt
Don't forget to also have the proper number of shims on the backside of the secondary. If your belt is too high it will squeel like hell and may even start moving on its own on flat hardpack.
The belt should be sitting just at the top of the secondary to slightly above. about the thickness of a penny. I can't seem to locate the exact spec in the service manual.
xsivhp
There are drawings for these in the tech pages ....
terret725
i have a regular alignment tool and thats fine. i can see the ware on the lugs of the belt.
xsivhp
terret725
is that for both or just one? cause i ahve the offset too i just want the center to center. or does any one have a used one they would like to sell.
