WTB: 1 Handlebar Grip - Viper
viper7mi
Michigan
Looking for 1 viper grip to go over my 45/90 hook. I think the viper grip minus the heat elment will work. If some has an extra Scott or similar grip that would do too. Black or blue.
a standard viper/any yamaha grip will not fit over a handlebar hook. Best bet will be to go with an arctic cat or another aftermarket 8" grip.
How would you take the heating element out of the grip, it is molded right into the grip.
Thanks, I thought it would. I say a pair of Scott grips that if I cut off the end and add to the hook that might work. The AC grip is great looking and I like your sleds grip look. I just don't want to get all new grips, heat elment and wire. I wonder what the inside diameter of the AC grip is? Where can I get one AC grip?
Not sure how to take the heat part out, crunch it inside with a pair of needle nose plyers. I think it might look good since it is the same materail?
That wouldn't be possible... it's molded into the rubber. I purchased two 8" Firecat grips for $14 from an AC dealer.
