EricMichael
I noticed some were longer than others..are these places on the sides of the head?thanks
skidooboy
you really need to invest in a service manual to help with everything on your sled. it is priceless. to answer your question, the long bolts go in the center bolt holes accross the center line of all three cylinders. ski
EricMichael
alright i'll try to get one at the dealer tomorrow, thanks though
eric email me at bkrpaul@aol.com and I will email you 3 viper manuals. Maxdlx
yamaracer18
does it matterif they goin teh center holes ofthe cyl? or not really just curiouse
skidooboy
yes it does!
The reason those bolts are longer is you will notice the holes are machined for locating dowels in them, thus the threads are at a lower point in the cylinder and it takes a longer bolt to engage the threads properly, if you ignore this you will most likely pull the threads out when you tighten the head bolts and will need to heli-coil the cylinder to repair it, I have had to fix them for people before from this overlooked step!
