more opinions on studs
MICHAELSF150
NEWFOUNDLAND
I have 96 down the middle now, I have another 48 to install. Should i put them in the middle of the track or outside the slide rails. The sled i have is a 1998 600 vmax sx, The track has 1" lugs and the studs are 1.080"
Thanks for any input. Mike :letitsnow
Hey Mike, you have the right studs, put them down the middle. Studs on the outer belt are nothing but trouble. You can go 3-3-3-3 or 4-2-4-2.
every sled I ever studded I installed studs on the outside because I wanted the most scratch lines I could get. I always thought the studs by the rails had the most weight pushing on them, for traction. I had 168 studs, 36 scratch lines on my 93 Exciter SX, 97 XTC, and 02 Viper before I 136'd it JUST MY OPINION
some people say that studs on the outside of the rails help in cornering and some say they make it harder to corner, which is it ?
studs
I have always ran studs on the outside but since I tried them on only the inside I won't go back to putting them on the outside.It's a personal preferrance I guess.
pro just have to ask why?
do you feel it turns a little easier? less pushy? out of the hole?
don't know if I will ever own a studded sled again but one never knows.
is the video you, Eric and? or did you just find it?
