SNOWRULES
I have a 2000 sxr 700 with psi tripple stockblaster pipes, carbontech reeds, reed spacers, boost bottle, middle layer of head gaskets removed, rear srx cooler, heel clicker in the primary, 45/39 helix in secondary (from turk) with green spring, stock track with 144 studs and max perf transfer rods. Just wondering what a good clutch setup would be? also wondering what jetting to run with those pipes? i have all 150 mains, needle is set at clip position 4, and stock pilots. is this ok for jetting? any help would be great thanks
Jetting sounds a little fat but a lot cheaper to start that way ; check plugs & piston wash & then go down if need be. Remember tho; riding at -10 on a good air day requires lotsa fuel so what ever your running now won,t be the same in mid-winter.
SNOWRULES
What about for clutching any suggestions for a good starting point?
Run whats in it & let me know what rpm,s it is turning. I need something to work with.
SNOWRULES
i don't know where to start though. have the heel clickers but don't know what weights to put in them for starters.
yamyrider
do you have weights that were in the machine already and what spring is in there.
The weights will be marked on the side. I have a 2000 SXR with Aaen pipes and like the 8Dn10 but have heard great things about the 89l as well.
SNOWRULES
no i built this machine up from bone stock did almost all the mods over the summer including buying the heel clickers. i guess i'll just go by the literature from the company for setup on a tripple piped sxr just found that it can be way off that's all.
yamyrider
http://www.totallyamaha.net/forums/showthread.php?t=22939&highlight=heel+clickers
do yourself a favor and read this post. You need to know the RPM that your pipes want to run at.
mrtahoe
What is peak RPM on a stock SXR? 8300?
yamyrider
yes stock is 8300 rpm
those pipes run at 9000 rpm/...
SNOWRULES
thanks i had found that post before but couldn't find it again
