fortress
Hello! well, Now that my sled is back and starting fine, i did take ride to see if the performance were there and............. they werent there!!
Shit!! sorry, I,m frustrated.. The rpm goes to 8000 and stabilize to 7800 and i can't reach more than 145 150 km/H.. The engine is fine, the 2 cluch are fine and the stator seems fine! So ??? i dunno what to do
I'm really wondering if i should not try another CDI box. I want to know if that little box can be parts of the trouble?? OR this box only work or not and can't be a part of the problem
Maybe the Throttle overidde system???
What you think??
What you think??
92vwgti
check and adjust your powervalves my machine was like that last year and now that i adjusted them i have alot more top-speed
fortress
hi!! thx for the suggestion but the problem isnt there.. All the simple thing have been checked and i can't find something
i'm sure its something electrical, its why i ask!!
yamyrider
is that an srx600 or 700
bluelightning
sounds like a clutch issue to me
fortress
its a 700 2001
again, the clutch have been serviced.. Nothing wrong. i have new roller and bushing etc etc.
Definately sounds like some kind of powervalve issue that u are overlooking. It would help if you had another srx you could swap parts with till u found it. This troubleshooting is very frustrating!!!!
fortress
Turk said:Definately sounds like some kind of powervalve issue that u are overlooking. It would help if you had another srx you could swap parts with till u found it. This troubleshooting is very frustrating!!!!
Turk, what about the Cdi? i want to know if it can be a possibility?? i will try to find one used if you think it can be the problem
I did check to powervalve this morning. the srx was idling at 900 and the valve fully opened.. even the dealer did check the sled last year and he didnt find something wrong
I had a 600 SRX in 99 that only pulled proper rpm,s when it was warmed up. If it sat for even 5 mintes it wouldn,t get over 8k rpm. New stator fixed it; but CDI could be a possibility.
fortress
Turk said:I had a 600 SRX in 99 that only pulled proper rpm,s when it was warmed up. If it sat for even 5 mintes it wouldn,t get over 8k rpm. New stator fixed it; but CDI could be a possibility.
well, i did check the stator like they said in the manual shop and it seem ok.. SO, i will try to find a cdi box, I'll begin with that!!
But what the cdi can do to prevent the sled to fully pull?? They control the sparkplug? how the sparkplug can affect the rpm??
yamyrider
this is one of those problems that is going to require time and patience to find.
It can be power valves, electical CDI, stator and it can be clutching....do you know anyone with a 2001 srx that you can swap parts.
fortress
yamyrider said:this is one of those problems that is going to require time and patience to find.
well no!! the srx are really rare in my area. Its all Bombardier!!
I have find a used cdi box.. i will begin with that but i'm still wondering how the cdi box can prevent my sled to pull. How the cdi can affect the rpm?!?
fortress
this guy seems to have the same problem than me
http://www.totallyamaha.net/forums/showthread.php?t=20599&highlight=CDI
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Take off the black servo cover on your power valve servo and physically watch the servo and make sure that it is pulling the power valves. Lots of the time you cant know it is unless you pull the cover and watch them pull. If they are not pulling the cables, let me know and I will help you out. Thanks
fortress
2ooosrx said:Take off the black servo cover on your power valve servo and physically watch the servo and make sure that it is pulling the power valves. Lots of the time you cant know it is unless you pull the cover and watch them pull. If they are not pulling the cables, let me know and I will help you out. Thanks
already done
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
You checked you actual cables and powervalves and made sure they arent pulling through right? Cables arent broken?
Exciterfan
If I were you, I'd try to find a used stator before trying the a CDI route. A stator will likely be cheaper than a CDI box. Sometimes a stator will pass the static tests (ohm meter), but not pass the dynamic ones (with the machine running and heated up). Those coils can be intermittent and temperature dependent.
Just my 2 cents! Good luck.
chilli
what about a simple fix first?? like new plugs all around? I had a brand new plug(cough cough) that was a P.O.S. right out of the package.
I overlooked that when trying to find the problem (which sounds exact same as yer problem), cuz I said to myslef....NO, those are brand news plugs, gapped perfectly!!!......and I was beating my head against the wall......in the end, I got raped for another set of BR9ECS', but voila....the thing was instantly back to a 100MPH+ sled again
Sounds funny and too good to be true, but never know!
fortress
chilli said:what about a simple fix first?? like new plugs all around? I had a brand new plug(cough cough) that was a P.O.S. right out of the package.
lol! but already done that.. I'f asking about the cdi, its cuz everything else have been verified
Well, i have find a used cdi for 75 bucks, I'll try that, and it it doesnt work, i'll try a new stator...
motodave289
Sounds like your having problems with hand warmers also. Did you check for short in harness under engine. Just a thought before you put cdi on. Also you say your only getting 12volts at 5000 rpm. My 2000 shows 13.6 V at idle. Maybe stator is week.
