ReaperSRX
Hey guys, i found out what was causing the binding in the front of my skid. One of the hyfax screws let go causing the hyfax to drop a little, i guess i was lucky it didn't come off! Anyway now what?.............I have read about drilling out and using nut and bolt. Could somebody give details or better yet post pictures.............thanks...........James
kysledneck
easy out ?
silversnow
Drill it and tap to a bigger size.
Snow Please!!!!!!!!!
you cant do that its not wide enuff.. mine did the exact same thing ..i was forced to move down a half inch and drill and tap a new hole!.when you get new hyfax you have to drill a new hole in that twosilversnow said:Drill it and tap to a bigger size.
ReaperSRX
How about drilling through and using a bolt and nut........anybody?......James
ReaperSRX
A picture is worth a thousand words!........thank you...........James
I started explaining it, then thought..I will just take a picture!
That job was a quicky..I had guys waiting on me. That is what happends when you wait till the last minute. But worked good.
kysledneck
I still do not know why not use an easy out? You drill it, then use the easy out, backs it right out!
skidooboy
on the trail one time, grapeape and i drilled another hole in the hyfax and then in the rail and retapped the rail. ski
Stainless Steel screws and nylock nuts really complete the job!ReaperSRX said:A picture is worth a thousand words!........thank you...........James
ReaperSRX
That's what i picked up this morning, stainless steel hardware.....thanks for the info guys...........James
ReaperSRX
Got it all done, didn't take to long. I did have some issues on the rail that the screw was sheard off but in the end i got it to work. DoN'T know why with all engineering might at Yamaha they didn't come up with this to make it a little easier on the end user.................James
YamiSmurf
So they can sell more rails for those not willing to do the work, letting their dealerships do the install.
YS
YS
