Dave_Vmax600
pulling apart a phazer carb i accidently stripped a screw head "Phillips" so what am i to do?
Use a Dremel tool and cut a slot so that you can use a straight blade screw driver. Then replace with allen heads.
yamyrider
I used side cutter to slightly cut into the screw and twist it out. works well and it is quick.
ExpertXViper
When such a thing happens I just use NEEDLE NOSE VISE-GRIPS....... Works everytime, but if it dont in your case like state above just cut a slot in the head.
ditto on the vise grips, and go to lowes and get 4mm allen head screws. Maxdlx
Dave_Vmax600
i hate Phillips screws.....what a dumbass idea for making star screw head
FuzzButt
When in doubt use a hammer blow screw driver. Aside form that notch it for a straight bit or use the side cutter idea. You might want to soak it in PB Blaster a bit before your next attempt.
Yamahammer485
Dave_Vmax600 said:i hate Phillips screws.....what a dumbass idea for making star screw head
Wow, you sound exactly like me!!
I say that even when I dont strip the head of one, they dont belong on a machine IMO. If they have to use screws, they should be robertson if anything, but I prefer haxagonal bolt heads and allen heads.
Was takking apart the carb on my Honda ATV, and I did that very same thing, strip a phillps head screw, so took my dremel with the reinforced cutting wheel and cut a slot in the head. There was no room for vice grips or even pliers. Also, the reienforced wheel is the only wheel to use, the other ones are extremely crappy and shatter all the time, theyre 100% useless.
I stripped two out of mines yesterday and I just drill em; out with a small bit and unscrew the rest with my finger worked great....Try that maybe
