SWEDE
A while back I remember some talk of ceramic coating and/or wrap for triple pipes to hold in the heat for better and more consistent performance.Has anyone experimented with this on sx or viper single pipes?It seems the mid section of the pipe would be the most important section on stockers.Would this be beneficial or a waste of time and money on a single pipe?
yamyrider
on a single pipe it looks
but there are better mods to give you more performance. Thin headgasket, reed notch and clutching will give you the better bang for the buck.
but there are better mods to give you more performance. Thin headgasket, reed notch and clutching will give you the better bang for the buck.SWEDE
Ok, I was curious about that, Turk helped me dial in my clutching and jetting and that made a big difference already.
yamyrider
have you done reed notch and head gasket mod....this will make another big difference to that sled.
SWEDE
No, I have not, call me a worry wart, but I was worried about reliability issues. What do you think?I was not sure about the silencer mod because of increased noise,have you done that and what did you think?Being able to run cheap gas was a another reason why I was hesitant about the head gasket mod.
yamyrider
I have done the head gasket mod and have had no problems for 3 years. You will want to do the reed notch or reed spacers.
Do the reed notch, it works better than the spacers. Maxdlx
T.S.U.Filmz
notch gasket and head mod all done to my 99SX and i have 8000 miles on stock Pistons sand it runs strong still
SWEDE
You have to run premium fuel with the head mod, right?Also are you guys doing one or two layers off head gasket?
change_up
With a single pipe you can take 2 layers out. With triple pipes generally you should only take out the middle layer, but there are a few exceptions (altitude being one).
If you only take 1 layer out with the stock pipe you could likely get away with running premium fuel. Actually I did this with pipes too... 1 layer removed and could only get regular. The sled ran fine, but for all I know i could have been cutting it close. Just run premium whenever you can.
SWEDE
Cool, the advice is much appreciated!
yamaha98sx700
What did you do with the clutching and jetting? Is this on a stock sled? I have a 98 that hasn't been touched and would like to do a little work on it with limited $$$.
Thanks!
Thanks!
Mrsled had his stock pipe on his sxr caermaic coated I would ask him what he thought of it.
i had coated pipes in my viper with a under hood temp guage, the coating may work for keeping heat in but it sure does nothing for the under hood temps and the temp of the air the sled is taking in to the air box. coated slps at trial speeds would raise the air temps to the air box 40/50/even 60 deg depending on the speed. with my srx pipes that were covered, 10-20deg difference. if i did it again, and i probly will, i would cover the pipes. this will make jetting alot more predictable.
ExpertXViper
BTV now what if you blocked the vents under the hood that leads to the airbox and pulled ALL your air through a Cold Air Intake that installs on top of your dash. Such as MPIs kit or SLP vents. Wouldnt this illminate pulling hot air from underneath the hood and pull in FRESH COLD AIR????
change_up
"If you only take 1 layer out with the stock pipe you could likely get away with running premium fuel"... that was a typo... insert regular here lol
SWEDE
Yes, my sled is stock and here is my setup.142.5 main jets straight acrossed and lower needles 1/2 position.As for clutching get a 51/43 helix, these come stock in rx-1's so find your self a used one.In the primary put 4.5 gram rivets in inner holes in flyweights.Thats it leave everything else alone in clutches, this setup runs excellent. You won't believe the difference in smoothness and response.I must give credit to Turk, he told me what to do, he said this is about as good as it will get for a stock engine.
SWEDE
I forgot to say, I have maybe 70-75 bucks in these changes I listed.
SWEDE
Thanks change up, I figured thats what you meant!
Jeff H
BETHEVIPER said:i with my srx pipes that were covered, 10-20deg difference. if i did it again, and i probly will, i would cover the pipes. this will make jetting alot more predictable.
"Covered" how? Do you mean "wrapped"? If so I agree with this. I've not done it on a sled pipe but I've wrapped the headers on my old 72 Chev 4x4 truck before and you could damn near grab onto them when HOT and not get burned. I've brushed hot headers more then a few times while working on the truck and with them wrapped there is no worry. Do that when bare and you get burnt deep. They have to be keeping underhood temps down like that. Maybe I should try the wrap on the sled pipe too??
