I have a 97 Vmax 600 with 6500 miles. I have a bog when I back off the gas, slow down and then hit the gas again--sounds like the primary is not popping back. I have to slow to a near stop and reaccelerate and everything is fine. Does not do it every time. Does not seem like a carb issue.I cleaned the primary and even put a different outer cover on with a better bushing since the bushing seemed to have a coating on it that was partially worn off. Spring is original. I was going to disassemble the secondary next.
Any ideas?
Any ideas?
