S.X. said:You have wars with everyone, what makes "JT" differant, is there anyone left from the old amsnow days that will still talk to you?? LMAO
Are you shure your talking about the same Tony,LOL
There can only be 1 "YAMMIEGOD"pro116 said:Are you shure your talking about the same Tony,LOL
S.X. said:There can only be 1 "YAMMIEGOD"![]()
So are you going to make it out next weekend??
YAMMIEGOD3:16
DUDE, ME FIGHT WITH ANYBODY ? NAW I AM FULL OF HAPPINESS TOWARDS MANKIND AND 4 STROKE OWNERS. 3:16 (tony)
It only took you 3 years before you could open your mind up that something else besides 8bu-00 weights could work in a srx there Tony.....LOL!!!
you can run them in your 02 as well theres differnt set up for drag, trail and speed runs.
We are headed to the UP this coming weekend for a week, so best case scenario for the ice will be the weekend of the 24th. If you want to try a couple of those helix's I can leave them out for you! let me knowjtssrx said:So are you going to make it out next weekend??
srx6
- Jun 29, 2003
Yesterday we went to the lake,my sled 99srx800 totalled grenaded two weeks before,so i was riding my buddies f36.We had his f3800 running like crap as usual(this is one finicky piece of *&$%,running pig super rich)He beat an f1000.the f1000 took off like a rocket but he hammered by 3/4 way down the track approx. 1000 ft or less just cones placed wherever.my other buddies f7 2003 was right behind it and coming on strong a little more track and he would have got it also.I would think a good running and properly set up srx would give them a good spanking provided they are stock as i assume this one was if not he must be one angry man.The only salvageable parts from my motor was the crank and 2 heads.4000 miles on big bore and 6300 on crank beating the hell out of it.crossover crank vents under motor(equalizers?) #1 fell out!!! even though it was supposed to be pressed in otherwise it would still be going strong spanking artic craps!
S.X. said:We are headed to the UP this coming weekend for a week, so best case scenario for the ice will be the weekend of the 24th. If you want to try a couple of those helix's I can leave them out for you! let me know
Do you have a 54/43 or a 54/44 Dalton? or even a 56/43 or 56/44? I'm looking for Dalton stuff they cut they them the same why Yamaha does.
YAMMIEGOD3:16
DON, I WILL NEVER ARGUE ABOUT HEEL CLICKERS AGAIN !!!!! I,LL I WILL SAY IS WOW!!! 3:16 (tony)
just teasin ya...Tony!
YAMMIEGOD3:16
HEY DON, WHILE YOUR HERE!!!! GOT A GOOD SET OF TRANSFER RODS YOU CAN PART WITH. 3:16 (tony)
No I dont, I never bought the aftermarket ones, instead I did the following, take off the lower part of the rod that bolts to skidframe, now shorten the top surface of it about 1/2-5/8", this will allow the transfer rod more gap and more transfer, fine tune to your liking by using the plastic shims. I cut the plastic shims(unless the super thick ones) and then you can snap them on and off without taking the rods off, cut them diagnally.
Tony I have a set of maxximum performance one's on an 01 srx I just bought if your interested pm me.
YAMMIEGOD3:16
DON, MY PROBLEM IS THE OTHER WAY. NEED LESS TRANSFER. YOUR WAY THOUGH IS EXACT WHAT I WAS THINKING THOUGH. !! 3:16 (tony)
PRO116, DROP ME A EMAIL ASAP ramsr1@aol.com , i,ll probley take them. 3:16 (tony)
I think I only have one Dalton and it is someware in the range of 48/41 ish, you can try it but that one is destined for my SRX. I will look tonight, give me a call.jtssrx said:Do you have a 54/43 or a 54/44 Dalton? or even a 56/43 or 56/44? I'm looking for Dalton stuff they cut they them the same why Yamaha does.
I've got a 48/40 Dalton. I'm using a 51/43 right now. I want it to shift a little quicker and load the motor harder out of the hole. See what you have and let me know.
YAMMIEGOD3:16
PRO116 YOU HAVE PM !! 3:16 (tony)
YAMMIEGOD3:16
RYAN, MONEY ON THE WAY !!! BOX THEM UP. 3:16 (tony)
