EricMichael
alright guys...soem of you know that i've been complaning about a vibration problem...well...i've done everything i can and know to stop it..Heres a list of what i've done: Clipped ALL lugs above and below windows on this 03 predator track, clipped them enough that if I clip anymore it wont be worth having the damn track..reached up inside of the tunnel felt to see if the track can hit the protectors and it can..but even with no lug it stiull could touch the protectors..I've tried tight tight tight track tention, stilld oesn't make a diffrence..I put the sled on a stand and rev it up and you can hear/feel vibration in the sled..the engine torques to one side quite a bit...i've looked down and can't see any broken motor mounts...could a mount be the problem?it does it low/high speeds under accelertaion...I need help..the riding season is prime and i'm sitting here scratching my head..
