YAMMIEGOD3:16
100 OCTANE, and still can use 00/02 jetting !!!!! 3:16 (tony)
Skidooslayer687
Alright thanks a lot mrviper, the stock 02 jetting is way to lean for my machine. The jetting that i am running now is borderline on being lean thats why i want to go up another size. I'd much rather be rich then lean and burn the motor, thats me anyways.
With fuel, the octane is the fuels ability NOT to burn, so running race gas, although it will keep the light from blinking will make less power unless the engine needs the octane level. If you could feasibly do it, a engine running on 87 octane will make more horsepower then one on 100 octane in the same engine, unless the engine is made to run high compression, advanced ign timing, etc.
In your case, if you dont have the option of ease, to mix the race gas in with your fuel, your gonna have to jet up, this will diminsih the heat as your basicly cooling the combustion chamber and pistons tops off with fuel, while all not that bad, it will still run good and not have any ill effects.
It also depends on the riding you do and your basic temp, seeing your up in Canada, your most likely colder then here most of the time, fuel quality im sure isnt as good as here and bigger jets would be in order. Lean is mean in short running distances(500-660ft drags) but the motors require alot of fuel to show you good mph on a long run, fuel is mph!
Skidooslayer687
Alright Mrviper, thanks once again for your help. Im going to go another jetsize up and try it out again. Once i do this i'll report back with the results. Yes it is very cold up here lol, anywhere from -5 all the way to -30 Celsius.
YAMMIEGOD3:16
DO WHAT DON TELLS YA, IF LITE STILL BLINKS IN THAT 02 SRX WHICH IS THE SAME SLED AS MINE, RUN A 50/50 BLEND. MY 02 IS STOCK, I BUY 100OCTANE, ACTUALLY 98 MOTOR RATING WHICH REALLY IS HARDLY HIGH OCTANE, NO BLINK IN TWO YEARS RUNNING 1/2. TELLING YA YOUR PROBLEM WILL BE OVER. NOW NOBODYS TELLING YA FULL BLOWIN RACE FUEL IS THE ANSWER, IT WILL MAKE YA RUN SLOWER. BUT ALL YA NEED IS TOO UP OCTANE AND THAT WILL KEEP DCS LITE OFF. WHICH IS YOUR PROBLEM. LIKE DON SAYS , IF YA CAN,T FIND RACE FUEL, JET UP !!! 3:16 (tony)
Skidooslayer687
Alright thanks guys for your help. I'll try it out and report back
