RIVERRUNNER
I am wondering if anyone out there has a hard time starting there srx in temps below -5 degree F. Today I went out for a ride on the lake and the temps last night were -20. I tried to start my sled at noon and it was about -5 degrees out and I must have pulled it about 25 times before it started to pop. It took about 35 times before it would run by itself. I had a half of a tank of new 91 no nox in it and I drove the sled about 3 days ago, any ideas????? I run yamalube for oil. I even tried a new set of sparkplugs and it does not make the sled start better. The choke cable is set to yamaha specs. I am out of ideas, hopefully you guys can solve my problem. Once I got the sled running it ran perfect!!!!!!! How many pulls does it take you guys to get your sled started in these temps? What can I do to make it start better??????Thanks guys!!!!!!!!!!
P.S. I don't think that I could get my sled running at -20 below 0. I don't think that I could pull it enough for it to start!!!!!!!!!!!!!!!!!
a little trick you can try is when you shut it off after riding for a day, hit the choke before shutting it off for the night, this will make it richer inside when you go to start it the next time.
EricMichael
buddy has an 01 srx and it does the same thing in cold temps..found out it was water in the fuel freezing the fuel pump/lines it would start then take forever to start again.Mind you 93 octane..I dunno about them gas stations now adays
92vwgti
when its -25 out my machine start in exactly 8 pullsi have a can of quick start handy just incase
RIVERRUNNER
MY Sled takes about 8-10 pulls if it is in a heated garage at 70 degrees!!!!!!!
When it's really cold i do like mv said, kill it with the choke,,try it.
RIVERRUNNER
Thanks guys, I will try the choke trick and get back to you!!!!!
check the rail that pull the choke piston on the carb the fork use and after it doesnt pull the choke on the carb no more the rail goes sideway but doesnt pull the choke piston
Skidooslayer687
The other day it was around -35 out, my sled was in the back of my truck and i unloaded it and fired it up. Fired up in exactly 5 pulls. The only time i've ever had a hard time starting mine was when its already warm, then it takes 2 or 3 pulls and a touch of throttle
blue missile
my srx 7 starts in 4 or 5 pulls no matter what the weather, or temp. clean those carbs it'll help. by the way these are hard fast pulls kinda feels like trying to pull start a locomotive though.
RIVERRUNNER
I clean the carbs and set them to spec via the service manual, so I am going to try mr vipers trick and see if it will help.
did u take a look at the rail that pull the piston on the carb for the choke ?
Let us know,but you shouldn't have to..RIVERRUNNER said:I clean the carbs and set them to spec via the service manual, so I am going to try mr vipers trick and see if it will help.
RIVERRUNNER
Yep, everything looks like it should. The choke opens up all the way.
then the choke circuit must be plug up
RIVERRUNNER
Hey mod please explain what you are talking about when you say the choke circuit is plugged up?
SRXtrafast
I have the same problem w/ my srx6 and 7. Many pulls. Right now it's about 5 above[f] and it would take 7-10 pulls on each sled but put a hair dryer on the carbs for about an hour and 3 pulls. Sounds like using the choke at shut down would work too.
RIVERRUNNER
tttt..
Your choke plunger passages may be plugged,need cleaning..RIVERRUNNER said:Hey mod please explain what you are talking about when you say the choke circuit is plugged up?
blue missile
too much choke and foul the plugs and you'll be pulling your arm off for nothing.
