Srx6 hard time starting
If your choke checks out to be Ok, next time you have this problem warm up the fuel pump. I use those throw away handwarmers(of course if you have access to a hair dryer works just as well). I have had this problem periodically with different sleds. This has always been after sitting outside all night in below zero weather and trying to get it started the next day.Get the handwarmer nice and warm and lay it on top of the fuel pump for couple minutes. They have always started for me after doing this. I am convinced the problem is condensation in the crummy gas these days. Hope this helps,Soc
when sitting, my srx starts on the 3rd pull 90% of the time even at 20+ below
When warm, 2 pulls max
Something is screwy with yers......could be some h2o in the tank or lines
Went back to this post after figuring out what my problem was. I bought the sled from someone that had added about 8 inches of fuel line and a shut off valve right next to the inlet on the gas tank. I pulled the stuff off just as a trial and error fix and it worked. The sled now starts on the 3rd pull in temps around 0. I have yet to try it in anything below that. I hope this helps someone else out.
