Diceman
Sled is running good...opens up well..seems fine but.........when I start the sled in the morning the track will be turning without giving it any gas....same as when I get home from sledding and put it on the stand the track turns ????I am mechanically challenged so if you have a quick fix or a long one please reply ...Thanks....Diceman
change_up
How fast is it turning? If it's turning too fast try taking the 3 washers out of the secondary clutch on the back side (you will see them when you take the secondary off... there are 3 little bolts and the washers are behind them...) taking the washers out will allow the secondary to stay open a little more therefore loosening the belt a little.
If the track is just slowly creeping when the rear of the sled is on a stand that is perfect... exactly what you want. If none of that helps either your belt is too short or you'll have to loosen your motor mounts and push the motor towards the back of the sled a little... I may have missed something so somebody else will likely correct me, but it's a start.
Millinocket Rocket
when the sled is running on stand the track should just jerk along slowly
oops-- change up beat me to it-lol
What is it idling at?(how many RPM's)
Diceman
I am not sure what the rpm is set at but I am sure it is not set too high. Like I said I am still new to sledding so don't know alot. The secondary clutch is the larger one right ??? The one on the side of the engine ?? Thanksdaman said:What is it idling at?(how many RPM's)
viperking
yes the secondary is the larger clutch. it is the one farthest back towards the rider. see what rpm's it is running at.
Diceman
Couple guys told me maybe my belt is toast but I can not see that being the problem??
we need to know what your rpm's are at idling (it's the gauge on the right)
Diceman
1500 rpm...same as last year i thinkdaman said:we need to know what your rpm's are at idling (it's the gauge on the right)
Ok thats perfect then,your belt must be too tight,can you take your
big clutch off,the one at the back of your sled?
yamyrider
as said by change_up if is spins a little or jerks along that is good. You want the track to spin a little when on a stand. How bad is it spinning.
Diceman
and do what???lol Dicemandaman said:Ok thats perfect then,your belt must be too tight,can you take your
flying dutchman
OK, so rpm is good.....whoa whoa whoa.....before ripping things apart.....
How fast is the track turning????
Like mentioned already, if it is just creeping along, that is perfect.
Diceman
well it is not creeping....not sure how to say how fast it is turning....it is not spinning really quick but it is spinning alot faster than last year.. it is definately faster than a creep...when I drop the sled off the stand the sled does not move, make any funny noises, sounds fine....Thanks again boys....flying dutchman said:OK, so rpm is good.....whoa whoa whoa.....before ripping things apart.....
If it's more than a creep your belt needs to be loosend up or yourDiceman said:and do what???lol Diceman
track is too loose.
if need be take your clutch off and remove a shim(washer )
behind all 3 bolts shown here,
that don't sound like a tight belt thoDiceman said:sled does not move, make any funny noises,.
Diceman
Hey Daman..you might have fiquired it out...Last year I was having a problem with wearing out sliders quickly..I was told to loosen the track....I did the
1 1/2 inch delection but it still seemed too tight.This year I loosened it alittle more. Why does the track being loose make it spin ???
Less resistance, it will spin easier if the track is looseDiceman said:Why does the track being loose make it spin ???
you need to tighten her yup some
Diceman
The 1 1/2 inch deflection I tried last year seemed too tight...when I set it to that last year I was going trhrough sliders......what do you suggest ??Thanks againdaman said:Less resistance, it will spin easier if the track is loose
Hmmmm..that was to tight, is that pull down sag or gravity?Diceman said:The 1 1/2 inch deflection I tried last year seemed too tight
