marty f
what steps do i need to take to remove and clean my carbs
do you have to take any cables off(choke ,throttle)POWERPACK said:look in the tech pages!! you take the airbox off, then close the carb heater, so when you disconect the two hoses it doesent leak so mutch.. then loosen the boots and take off the fuel lines.. in short.. then you take of the bowl in bottom of carb and you can see all the jets, take them out and clean with compressed air! then put it all back..
