OK my most rear shock is shot. The yamaha dealer only knows that the stock shock set up that comes with the works (coil, mounting parts, bushing) is $390. OUCH....
They are having troubles matching up an after market shock as the normal VMAX shock is not compatible nor is the 97 Pro Action compatible.
Any one know a replacement shock for a 96 XT Pro Action rear most shock?
seca
i think that any long trav. shock from a 97 up pro-action will work. you can get them here on this site for cheap.
I dont know about that one....Daman info on this...
mid 90's v-max's
skibkr-
I don't know for sure if any of the other pro-action shocks will work but I would think they would. Another option is e-bay. I found a complete working 96xt rear suspension for less than 150$ that I put in my 94. Good luck.
I sent mine into Maxx Performance last season (RIP) and one of them was totally shot, as in the piston had etched the inside of the shock so bad. They sold me a used one and rebuilt that one. I think it was only about $40 more. I could be wrong on the amount. There are some out there though. Maybe check with Pioneer or someone else who does the revalving/rebuilding.
I'm thinking too it will work,P/N's are very close...seca said:i think that any long trav. shock from a 97 up pro-action will work. you can get them here on this site for cheap.
So does that mean I could use a set of Viper shocks??
Not totaly sure cole, i looked up the P/N's for your sled and a 98 P/aColes_55 said:So does that mean I could use a set of Viper shocks??
and they were damn close to being the same,they might dunno i personaly
never done it..
if i was to guess i would say yes.
