Anyone using Blue Marble oil in their SRX's.Should help keep the power valves clean.Have been using Blue Marble in my SXR for second season now and it is running great.
The attraction of Blue Marble's patented surface conversion technology to metal is so stong that it removes all existing engine deposits. In doing so, the deposits end up on the power valves. Once the deposThe attraction of Blue Marble's patented surface conversion technology to metal is so stonThe attraction of Blue Marble's patented surface conversion technology to metal is so stong that it removes all existing engine deposits. In doing so, the deposits end up on the power valves. Once the deposits are removed, Blue Marble will keep your engine and power valves clean. Some oils (particularly some synthetics) are very bad for leaving heavy engine varnish deposits. Remarkably, those deposits can build up in a very short period of time. If you wish to accelerate the cleaning process, use a 2 cycle engine cleaner like "OMC Tuner".g that it removes all existing engine deposits. In doing so, the deposits end up on the power valves. Once the deposits are removed, Blue Marble will keep your engine and power valves clean. Some oils (particularly some synthetics) are very bad for leaving heavy engineThe attraction of Blue Marble's patented surface conversion technology to metal is so stong that it removes all existing engine deposits. In doing so, the deposits end up on the power valves. Once the deposits are removed, Blue Marble will keep your engine and power valves clean. Some oils (particularly some synthetics) are very bad for leaving heavy engine varnish deposits. Remarkably, those deposits can build up in a very short period of time. If you wish to accelerate the cleaning process, use a 2 cycle engine cleaner like "OMC Tuner". varnish deposits. Remarkably, those deposits can build up in a very short period of time. If you wish to accelerate the cleaning process, use a 2 cycle engine cleaner like "OMC Tuner".its are removed, Blue Marble will keep your engine and power valves clean. Some oils (particularly some synthetics) are very bad for leaving heavy engine varnish deposits. Remarkably, those deposits can build up in a very short period of time. If you wish to accelerThe attraction of Blue Marble's patented surface conversion technology to metal is so stong that it removes all existing engine deposits. In doing so, the deposits end up on the power valves. Once the deposits are removed, Blue Marble will keep your engine and power valves clean. Some oils (particularly some synthetics) are very bad for leaving heavy engine varnish deposits. Remarkably, those deposits can build up in a very short period of time. If you wish to accelerate the cleaning process, use a 2 cycle engine cleaner like "OMC Tuner".ate the cleaning process, use a 2 cycle engine cleaner like "OMC Tuner".
lets hear it boys...your brands.
schaffer oil
bigtsrx
- Apr 9, 2006
hey monster, I've been running blue marble in my 02 srx for the second straight season and absolutley love it!!!!!My brother uses it in his 01 srx and also loves it!So there ya go!I would recomend it myself.I guess it's all what people prefer or whatever works! Awsome oil!Good luck monster!
what do your powervalves look like after a season with the blue marble?Some of my buds ran it in there doo's and after a couple gallons they seen a 2mpg increase on there sled.
Interceptor for the first time this year in all my machines....
is that why your sled just sits in one spot all day long and not move daman..LOL
Well I am going to put Blue Marble in my SRX and see how it runs and if powervalves stay clean.
I'll have to get some of the Amsoil out the oil tank before I put Marble in.How far down do I siphon the oil out to avoid an air lock in the line.How far down does the oil drop in the tank before warning light comes on.I have about 3 inches of oil left in the tank now.
keep us posted blueball...LOLbluemonster1 said:is that why your sled just sits in one spot all day long and not move daman..LOL
blueball...where did that come from LOL.The name is MONSTER!!!!!!
when i had the air box off mine i sucked it out dowm to 1/8 inch frombluemonster1 said:I'll have to get some of the Amsoil out the oil tank before I put Marble in.How far down do I siphon the oil out to avoid an air lock in the line.How far down does the oil drop in the tank before warning light comes on.I have about 3 inches of oil left in the tank now.
bottom then dimed in.
i think you got a good 1/2 qt+ left when the light comes on..
thats a good thiong yo check to make sure it's working..
LMAO!!!!!! your bashing my sitting still srx!!!!bluemonster1 said:blueball...where did that come from LOL.The name is MONSTER!!!!!!![]()
well it hasn't moved for some time,what am I supposed to think....eh!!
At least turn it around and point it to the other direction and make us think you have been riding it..LOL
Shes too fast i can't catch her...bluemonster1 said:well it hasn't moved for some time,what am I supposed to think....eh!!
and why you draining out the ams? thats better than blu m..
I talked to the guy that made BLUE MARBLE extensively one day... I was REAL IMPRESSED with his knowledge of lubricants, although NOT using a synthetic base stock, i was REALLY IMPRESSED with his additive package!!!! If I wasn't LOYAL TO KLOTZ, I would DEFINATELY USE BLUE MARBLE!!!! and PLEASE do not refer YAMALUBE as "yamaha OEM" Please refer to it as CITGO GARBAGE!!!!! Thanks!!!
Skidooslayer687
lol good old yamalube or "citgo garbage" LOL is definately not a good oil, ran it for 1 year, did not like it at all, plus the amsoil smells better lol
Use amsoil and get the best of both G....nosboy said:although NOT using a synthetic base stock, i was REALLY IMPRESSED with his additive package!!!!
I ve never had a conversation with the BRAINS behind AMSOIL.... Ive done LABS in school on Amsoil (1980) and was VERY IMPRESSED with their product... personally, I think their marketing strategy STINKS and I REFUSE to purchase a product from a DUMB HILLBILLY that THINKS he knows all about oil... I was EXTREMELY turned OFF by the JIBBERAGE and ABSOLUTE GARBAGE coming out of the AMSOIL distributors mouth at the NOVI snow show a few years ago... He probably thought i was a BACF (backwards A$$ country ****) like HE WAS...but... I PAYED ATTENTION in CHEMISTRY class!!!! After listening to his GARBAGE coming out of his mouth for about 10 minutes, I started asking him questions that I KNOW he couldnt answer,,, and,,, needless to say,,, he came up with the most OUTRAGEOUS NONSENSE I have probably EVER HEARD in my LIFE!!!!!!!! After I started calling him out on his CRAP,, he did the SMART thing and told me that he had OTHER PEOPLE waiting on him and our conversation was OVER.. I would rather be DAZZLED with BRILLIANCE than BAFFLED WITH BULL$HIT!!!!! I will NOT TALK BAD ABOUT THE PRODUCT,,, because I have seen it with my OWN TWO EYES,, but I will NOT give my money to some BACF hillbilly that talks a load of CRAP!!!! I like KLOTZ, I like the company and I also like the sales people!!!! I also like BLUE MARBLE.. I could hold an intelligent conversation with him and he doesn't have to BAFFLE me!!!!
I use to use amsoil until I blew a few engines.
