wash600
I have a 2001 SXR 600 and was wondering if anyone could tell me if the water temp light and or the low oil light is suppose to flash at start up to show that the system's are working properly. Mine at this point do not. My old 1994 vmax use to. Thanks for your replys!
sledheadsxr600
Yes the temp light should flash three times at start up.
wash600
Yes I know this on the hotter ignition SXR's, 2002 and newer, but is it the same for the 2001?
wash600
To the top.
Yes should flash 3 times...
wash600
Well mine don't! All the bulbs are good and I jumped the wire in the plug while it was running and the water temp light came on, so it looks like the high temp system is working as long as the sensor itself is not bad, anybody have any suggestion's? Thanks for your replys.
wash 600
wash 600
wash600
to the top
Exciterfan
I have a 2001 SXR600 and I don't believe mine flash three times?????
I have an electronic copy of the owners manual and it says NOTHING about the lights flashing on startup. I'm thinking it was a 2002 thing.
I can email you the manual if you want?
Can any one else chime in????????
wash600
To The Top.
Budweiser
I have a 2000 SXR 700 and the lights don't flash...
Hmmm..i thought on that sled they did,,that must not be the case then...
roudyroy1
my 700 doesnt either! im worryed it should i know that for a fact, what did you do?wash600 said:Well mine don't! All the bulbs are good and I jumped the wire in the plug while it was running and the water temp light came on, so it looks like the high temp system is working as long as the sensor itself is not bad, anybody have any suggestion's? Thanks for your replys.
wash 600
Devilin AblueDress!
roudyroy1 said:my 700 doesnt either! im worryed it should i know that for a fact, what did you do?
http://www.yamaha-motor.com/sport/m...eD9scz1zcG9ydA==/Owners Manual/starthere.aspx
Heres the link to down load a manual for your sled. You dont have to order or pay for anything, go to the tab on the right that say "proceed to manual" He hasnt posted in 5 years so doubtful he will answer.
roudyroy1
So did he mean the plug at the temp sensor he jumped? Thank you did!
CeaRay
I just picked a SXR 01. The manual was in great shape.
"Light Bulb check:
Light flashes three times, then goes off."
Coolant temperature warning light
After the engine starts, this light flashes three times to check the bulb, and then goes off if there are no problems. (See page 5-5 for warning light flash pattern number 0.)
If it does not flash, have a Yamaha dealer inspect the electrical circuit.
Above is word for word from the Manual.
"Light Bulb check:
my 01 SXR600 does not flash at start up and never has ..just my SRX flashes 3 times at start up.
roudyroy1
only the 2001 700 does, alright to i have narrowed it down. i went to my sled i know works. and jumped the temp connector. the light came on, so i proceded to do the same to the problemed sled. the light didnt come on. so i took the bulb out and it tested okay. so now i get the fun of tracing wiering down. f me right
Devilin AblueDress!
bluemonster1 said:my 01 SXR600 does not flash at start up and never has ..just my SRX flashes 3 times at start up.
Blue, the sxr600 upgraded to dual bulb with diagnostics in 02, the sxr 700 went to dual bulb with diagnostics in 01. Sleds with the single bulb,older igniton will not flash as they do not have diagnostics in CDI.
Roudy, is your "problem sled" an 01 as well? Seems you had sxr's,an 00 and 01? 01 should flash 00 should not.
roudyroy1
Devilin AblueDress! said:Blue, the sxr600 upgraded to dual bulb with diagnostics in 02, the sxr 700 went to dual bulb with diagnostics in 01. Sleds with the single bulb,older igniton will not flash as they do not have diagnostics in CDI.
yes thats correct, i do. problemed sled is an 01, i know the 00 wont flash. i will trace grounds and see if i have voltage and a solid ground at the temp sensor tommarow. if its good ill look at the green and red wire and see if that has a solid connection at the dash. and yes i have confermed the bulb is good.
