moss
My Belt is abit low in the secondary, and I wanted to Adjust this to be just .5mm above the top of the Secondary. Would I add Shims on the back 3 screws, or take out Shims? Also, where do I get the shims from? Dealer I guess?
Dealer...
Add..
Add..
You would add shims to raise the belt. I found some metric washers at my local hardware store that matched up good. Just try to keep the thickness the same on all 3.
moss
Perfect thanks Guys...I know its a simple thing, but just wanted to be clear.
nothing wrong with that..moss said:Perfect thanks Guys...I know its a simple thing, but just wanted to be clear.
yeah I put 1 set of washers to raise my belt a tad.Getting a slight squeal from the belt,but it is a newer one.Track turns with jerking motion when up on stand.No burn marks on the clutch.
