77 srx crank cases
ANDRE, YOUR THERE BUD. NOW. THAT SQUISH AIN,T THAT TIGHT FOR A SRX. PRETTY CLOSE TOO STOCK SO THOSE HEADS ARE NOT HACKED UP. AS FARR AS CLUTCH SPEC, PRETTY MUCH TEST WHAT I POSTED ABOVE IF YA RUN A COMET. YOU GONNA RUN THIS SLED ON GRASS OR ICE. 3:16 (yammie tony)
no the only year that had the longer pto end was the 80 due to the addition of the oil pump and the attachment of the drive gear on the end of the primary clutch
