Lets see what you SRX owners are running in the clutches,primary and secondary setups,gear ratio's and what your rpm's are like and your top speeds.Got to be an ideal set-up that works for most.
YAMMIEGOD3:16 said:I,LL POST EXACT WHATS IN MY 02 FOR YA. WHAT THE HELL DO I CARE. I RUN THIS SLED 1/2 MILE SNO DRAGS. ITS UNSTUDDED. NOW IS THAT A FACTOR ? MAYBE!! UNGODLY TOP END.
8BU-00 WEIGHTS (about 55 grams)
MAXXIMUM PREF. WHISRX- SPRING
HELIX,s I HAVE JUMPED BACK AND FORTH FROM A 50-40 TOO A 51-43
SPRING -GREEN AT 90 TWIST.
STOCK GEARING
STOCK JETTING,- RAN MY VENT TUBES TOO AIR BOX. I USE 100 OCTANE FUEL WITH MANY WOT RUNS. NO DCS ISSUES.
DON,T KNOW TOP SPEED, NEVER CHECKED, THIS IS MY TRAIL SLED. FIELD RACER. BEAT ZILLION OF SLEDS. ALOT HERE SAY 8BU-00 DON,T PULL TOP. THIS DOSE. 3:16 (yammie tony)
YAMMIEGOD3:16 said:JOSH, CAUSE IT WORKS. 1/2 MILE IS REAAAAAAAAAAAL FARR. THINK ABOUT IT. WHY CHANGE ANYTHING WHEN YA CAN PULL AWAY. NOW I AM REALLY CONSIDERING STUDS NEXT YEAR. THAN I MIGHT MAKE GEAR CHANGE. 3:16 (yammie tony)
