valin
Headed out this morning, and I found the issue. It had nothing to do with the timing, but I am pleased to have found the problem. Now I can try taking timing out again. Slowly making progress....
jabber800
Will you be ready for Northbay next weekend??? I'll be down in Alliston running 1000ft. runs..
valin
I'm not sure if I will be 100% ready, but I will be there. It will probably end up just being a tuning day there, since it is going to be raining here the next 2 days, and I won't be able to get ready.
jabber800
This weather sucks!! Just get enough snow to run the trails again and here comes the rain....
valin
Argh.....having fuel issues and running out of fuel. I have a feeling i was collapsing the pulse line since I was only using fuel line as the pulse line. I found a few specs of dirt in the fuel pump, and noticed that the hole in the needle/seat was smaller than that in the 680 mains I am running, so I enlarged it to accomodate. I'll get this thing figured out eventually. The next set of races are Feb. 16th, and 17th, and I should be ready for them.
yamyrider
Ryan you gonna run at rocky's
valin
Of course.
what weekend is rockys? buddy wants to run his featerweight doo. i have pics in my milage thread.
valin
23rd, and 24th of Feb.
valin
Well, I was out today. The track is completely screwed up, so I couldn't hold it down for very long. I did make a few 1000-1200' passes, and the motor is working fine again. I ended up spending $50 on braided automotive fuel line, ran an extremely hard pulse line, and re-plumbed my cooling system a bit. It was restrictive. I will head out somewhere tomorrow for some actual 2000' testing.
yamyrider
I am expecting to see that machine run at Rocky's in a couple of weeks...get er done!
valin
Ok. Today was a much better performance. I finally have the motor figured out, and have solved all of my fuel and temperature issues. I am running it at 14 degrees of timing after 7000 rpm, with VP C-16 fuel, and it is alive. Mind you, it is not completely burning the fuel and my pistons are wet, but it is still running well. I don't have enough compression for 16, but wanted to start safe, and it is.
For the first pass I took it very easy off the line, rolled into it, and pulled 143.1 mph. For the second run I tightened my loose track and put on a new belt and ran 145.4 mph with no traction off the line. I had to get off the throttle 3 times.
For the third run, i put a bit more transfer back into the sled, and it solved my traction issue, but by then the wind had changed to a strong side/head wind, and pulled a 145.5 mph.
The final pass was 146.0 mph. I had good traction, but fought the wind again. RPM is just a hair low. Pistons are still wet. Wash is large. Motor is still running
Now I can finally start to do some tuning.
change_up
Sounds like you should get to your 150 mph mark fairly easy this year.
valin
I attended the races again today. I only was able to run one good pass due to weather conditions, at 146.3 mph, and found another issue. The new wider 8DN belts are actually riding all the way up in the 8.5" MicroBelmont primary, and are therefore too short to run because it is shifting too far. The belt is tightening up near the 1800' mark. Luckily I did not break any belts, but it is limiting my speed. I am going to start to throw some gear at it becuase I am pulling a rediculous amount of overdrive anyways. I am only geared 23/36 at the moment, and have an unhappy chain angle as it sits with a 68 link chain. I wonder how much overdrive I am actually pulling to run 146. I'm sure it's damn large. It looks like I'm geared for 127.61 mph using this calculator, which equates to 15%.
http://www.snowmobileworld.com/tools/index.php
I'll throw a 24 tooth up top, and see how it pans out for my first gear test.
bluewho
Cool calculator i have this keyboard rocking!
valin
There have been two videos of the races this weekend put up on youtube. The first one I had to get out of the thottle a few times due to lack of traction.
http://www.youtube.com/watch?v=LdOIQpBcsag
http://www.youtube.com/watch?v=AmZ3fb86sjw
toydoc
A wide belt will add overdrive and shift area to the clutch face. Should have helped mph.
valin
I agree toydoc, but only to the point where it is shifting out fully in the larger 8.5" primary. The belt is a few mm too short for a full shift out.
