vmadmax
When performing the reed stopper notch mod do you need to modify the reed pedal?
no just the stopper. Go to the tech section it is in there on how too. If you do anything to the petals they are junk. Maxdlx
vmadmax
Thanks for the info, is this mod worth the effort?
jmp2204
well i did it (info from here ) and it certainly eliminated the low gurgle! it's worth....thanks ty again!
sockeyerun
Test Dummy
Yes it's worth it. I just changed from reed spacers to the reed stop mod. I think the reed stop mod cured the mid range burble problem better and also the reed spacers moved the carbs back just enough that it caused the steering collum(?) to rub on the center float bowl. not good. Soc
if your carb hits, install a couple washers under the back motor mounts.
installing a boost bottle makes way more of an improvement, what a different animal this sled would have been if sold with a boost bottle , srx syle reeds and notched.
also, drill the exhaust,
