viper plastics
SniperX
Ottawa Ontario
any one know if a viper belly pan will fit on a srx body, i had a viper motor in my srx before and i found a srx body and would like to throw my viper parts into it for a second sled,the motor went in with only minor issues,it would be ideal to use a viper chassi but have not seen any close
let me know
thanks
ya, you can do it. there is some variation from the bellypan fitment(mostly just the shock mounting tabs) to the bulkhead but you can put the viper bellypan, and all on a srx chassis, you will also need the viper inner front tubing bumper,bumper, braces, hood hinge,cable straps etc. to do it all.
I forgot to add that you will also need to cut and refit the pipes to work with a viper bellypan and hood also.
sorry mrviper700, i have a viper motor to go into it and i only had to dent the can a bit when i had it in my srx so i hope with the viper plastic and hood on it it will not be a problem
thanks for the help
