SniperX
any one know if a viper belly pan will fit on a srx body, i had a viper motor in my srx before and i found a srx body and would like to throw my viper parts into it for a second sled,the motor went in with only minor issues,it would be ideal to use a viper chassi but have not seen any close
let me know
thanks
let me know
thanks
I think what he is trying to say is, Will the viper plastics bolt onto a srx bulkhead to turn it into a viper.
ya, you can do it. there is some variation from the bellypan fitment(mostly just the shock mounting tabs) to the bulkhead but you can put the viper bellypan, and all on a srx chassis, you will also need the viper inner front tubing bumper,bumper, braces, hood hinge,cable straps etc. to do it all.
SniperX
Thanks Mrviper700 my new project begins
I forgot to add that you will also need to cut and refit the pipes to work with a viper bellypan and hood also.
SniperX
sorry mrviper700, i have a viper motor to go into it and i only had to dent the can a bit when i had it in my srx so i hope with the viper plastic and hood on it it will not be a problem
thanks for the help
thanks for the help
