SHAMARKEN
sweet looking sled!!!
srv540 said:Hey Chuck what the jetting on them 36mm flatslides? running a 50 pilot jet?
Buckzone101 said:did you make the bar risers?
hey man,
beautiful sled,
what should I use for cables in my 86 phazer build so that I can have a bar set up like this here?
also, what size track is this? looks like the 121" or 136"
thanks
-06 Nitro/Apex? handlebars
-07 Phazer handle bar pad
-Handle bar riser
-Exciter Pod and gauges
-Rear suspension dropped 1.5"
-Aluminum cross shafts in rear suspension
-Lightweight 8" rear idler's
-Tunnel supports
-Vmax 5/600 T.S.S. Struts
-USI Skies
-Riechards torque arm
-Bender cold air intake and hot air exhaust kits
-Belly pan skid plate
-1984 Phazer seat chopped and 4" of foam added to the top
-Widened to 40" ski stance
-New paint/decals
-Sx pistons (Garage cut)
-Boyesen reeds
-Gutted airbox
-Aaen Quiet Can with stock Y pipe
-Vmax 500 Flatslides
-Stock heads/gasket
-Lightly smoothed the exhaust and tranfer ports
-L.E.D. Tailight
Sled is now For sale, please contact Bill S.
(Vmax540 is simply listing this for him) at 814-354-2670 after 5 P.M for more info. Sled is located in NWPa.
http://www.totallyamaha.net/forums/showthread.php?t=42259&page=1&pp=10
-1995 Phazer
-Custom egt – cht guage
-Handle bar riser
-Tunnel supports
-USI Skies
-lightweight custom seat
-New paint/decals
-Sx pistons
-Boyesen reeds
-Gutted airbox
-Stock heads/gasket
-L.E.D. Tailight
-Newer .750x121 camoplast track never studded
-Asking $1450 or Reasonable offer.
Hey Chuck
What the jetting on them 36mm flatslides ?
running a 50 pilot jet ?
147.5 Mains and 32.5 Pilots !
I would like to know what jetting to use when using V-Max 500/600 Mikuni TM-carbs on the 485 FC Phazer Engine ?
