Skidooslayer687
uh oh, not good at all, sorry to hear fortress
fortress
where i can find these parts for cheap?
your not.......fortress said:where i can find these parts for cheap?
fortress
i was replying that the parts you'll need won't be cheap new or used....
post a ad here or check e-bay..
fortress
daman said:i was replying that the parts you'll need won't be cheap new or used....
well i saw a cylinder on ebay for 200$ better than 500
can you answer my questioN? does the 99 srx cylinder fits the 2001?
Skidooslayer687
lol definately not cheap stuff, i have a bag from yamaha, a dam bag and it cost over $700 and thats just gaskets, rings, seals and such, i wouldnt want to imagine what a head, piston and cylinder would cost from them, you might be able to pick up a cylinder and other parts cheap off either this website or maybe ebay but you would have to be careful off of ebay
You could keep a watch on ebay as usually there are heads and cylinders on there. There's one for a 99' on there now but I think it will have different porting than your's.
somone with more info on that will tell you but i think there different in onefortress said:well i saw a cylinder on ebay for 200$ better than 500
way...
'98-'99
'00-'02
Skidooslayer687
the porting is different on them i believe
mrviper700
VIP Lifetime Member
post pics, and you mise as well remove the (4) 14mm headed nuts holding the cylinder on and remove the cylinder, as to check the conn. rod while your there, it needs to come off to replace the piston and cylinder anyways. post pics so we can see whats going on.
fortress
mrviper700 said:post pics, and you mise as well remove the (4) 14mm headed nuts holding the cylinder on and remove the cylinder, as to check the conn. rod while your there, it needs to come off to replace the piston and cylinder anyways. post pics so we can see whats going on.
Mrviper, yes, i'm waiting to take some pic but we have a snowstorm here
and the sled is outside under a cover
i need to wait until tomorrow
but, if you check in the tech section in totallymaha, the section were you can see picture of bad piston, mine look exactly like the "smashed debris"
RIVERRUNNER
Ouch, sorry to here that man!!!!!!
