srx plugs???
We Own A Big Lawnmower Repair Center And Out Of All The Places (which Is A Bunch!) These Are The Only Ones I Can Get I Cant Even Get The Removeble Toped Ones And Im Givein 36 Bucks For 10 But Where Do I Go And Get Them Napa??? Carquest???
Ok Have U Had Any Problem With The Powder Bog I Cant Seem To Find The Prob Im Thinking Of Making Plates Out Of Dimond Plate With Holes In It To Go In The Lower Hood Vents ??? Or Do You Have Any Good Ideas?? O How Do U Get A Belt To Quit Squeling At Idle???
yamahaulinass said:
Ok Have U Had Any Problem With The Powder Bog I Cant Seem To Find The Prob Im Thinking Of Making Plates Out Of Diamond Plate With Holes In It To Go In The Lower Hood Vents ???
No i haven't had that problem yet, have you tried a search?, search
for a post by kimoaj, i think he came up with a fix for that..
yamahaulinass said:
O How Do U Get A Belt To Quit Squealing At Idle???
If your belt is squeling At Idle your deflection(belt) is too tight, what you
need to do is remove the shim's(washers) behind each bolt in your secondary,
then when you replace them it will spread the sheave and make the belt ride a little lower in the secondary.
I Havent Tried It Yet But Im Going To Work On It This Weekend And Ill Let U Know>>>....... How Many Of Them Bolts Are There To Take Them Washers Out? And Do I Take Them All Out Or Just That A Few Off Each Bolt And Try It?? Thanx Man!!
No problem..
there's 3 bolt, usally just one per bolt, but could be two,you'll
know it when ya pull em out, take the secondary right off too..
