What was worse about it? Ride? Transfer? Weight? Reliability? Can you share some more insight?overpowered srx said:i had an m-10 in my 98 srx 700 and it was the worst part i ever put in that sled it worked way better with the stock srx skid
bluewho said:The wife has a nice ride there.
batti srx said:Just installed an M-10 for the wife and looking forward to trying it out.. What do you guys think?
theblues said:What was you front spring preload set at before installing it...I have everything else but not the front spring preload...I'm a heavy guy, so my back is set at the 275 lbs 16mm of preload...I was going to call team fast to see what they say, but if you have some type of reference for me to start from that would be great...when the M-10 was shipped to me all the spring were off and the arms as well just laying on top of the skid…any help would be great…thnks
xsivhp said:What was worse about it? Ride? Transfer? Weight? Reliability? Can you share some more insight?
xs
overpowered srx said:ride was okay i wouldnt say all that much better if any than a stock pro action rear but the weight transfer was terrible nothing we did would make the sled hookup with that skid in it with the stock srx skid and bender transfer rods the sled would pull the skis and a do a radar run at the ice drags at 103 mph after i put the m-10 in the sled would spin the track like mad and wouldnt go faster than 92 mph in the ice drags as far as reliability i couldnt tell you about that as i didnt keep the skid in there long enough 2find out. i had 4 other buddys who all had the same problems with there m- 10s
fast was of no help with trying 2 sort that skid out either as everything they said 2 try didnt work either
BETHEVIPER said:that skid wasn't designed to be fast, tiny wheels in the rear and upper idlers, very long travel, tight coupling. the skid was designed to ride great and does. if you didnt find it to ride good, i would guess it was not installed and or set up correctly. you are the first i have ever heard say it didn't ride much better than a pro action.
i have installed two now and both rode super, hooked up great. you need to cut the blocks, and set the skid up with the limiter all the way out.
your wife is going to love that sled now.
nothing says love like an M-10
