SC10 2 into SRX
Do a mockup wham with the weight on the skid even with a bud on it checking if you like were it will sit.Should be easy with the brackets you have for the rear.The front maybie a block of wood to hold the axle away from the top of the tunnel.
If it sits to high remove the top axle and after checking the depth of the holes cut the axle to size and drill and tap the threads so you can rebolt.Or will another axle work?
just waiting on seals for chaincase then i will post pics of my new sc 10 III install.
Hey Blue,
Can you provide a little more detail on where to drill my new holes on my SRX, to input the SC10-III? Where do you first measure from and which holes do you need to drill out?
Thanks,
John
I will try john if you look at the 2nd last pic on page 1 you will see the rear washer in the original location and another behind it with the large allen key bolt that the doo skid uses.Meashure from that mount to the front of the sled 23 1/2 inch.
