heres an update. Went ahead and bought a new coil, put it on and thats not the problem. Sled will start and run but only the clutch side seems to be working like it should, and that is with either plug wire. The mag side will run if I pull the clutch side wire off but it will only run to about 2k and its boggy and just not good. when I had the mag side plug out looking at it I pulled the starter cord over and the sled started with only the clutch side plug in. Ther was a pretty good spray of fuel coming up out of the hole. So now I am thinking to much fuel in that side. Any help out there?
