i just use a piece of strap, cut it about 3/16 in too wide, chamfer the upper corners, bend them down and slide them in. they stay in great.
SRX7
dual carbides are the fix, I found shimming did not work. even screwing around with the rear skid may help a little then you loose what ever you have worked on to get your rear suspension right.
Duals work great thats what they were made for. Scrubbing speed not really, turning sharpness yes you loose a little but I would rather loose the darting than sharper turning aspects.
A K MtnViper
SRX7 said:dual carbides are the fix, I found shimming did not work. even screwing around with the rear skid may help a little then you loose what ever you have worked on to get your rear suspension right.
Duals work great that's what they were made for. Scrubbing speed not really, turning sharpness yes you loose a little but I would rather loose the darting than sharper turning aspects.
I think shimming really helps, but take note I went to dual carbide Simmons because that works best, just costs more than shimming.
Yama49601
JERSEYJOE said:I Am Working On A New Approach To The Shimming Idea. I Am Making Some Tapered Aluminum Wedges That Will Go Between The Ski And The Rubber. Sort Of Like Caster Shims For Solid Axle Trucks. I Am Making Various Tapers. They Will Apply Even Pressure Over The Entire Rubber And It Willnot Crush. The Rubbers On My Apex Crushed And The Shim Was Reduced To Nothing. If They Work I Will Have Lots Of Them To Give Out.
Cool if you have an extra set I'll take one (or two).
Well, I shimmed the skis with 1/4" delrin with stainless screws and I reduced the front preload quite a bit. I am also going to buy a set of easy steers from Royal Distributing, they look the same as what my old Formula Z had from the factory, they are only $14.95 for the pair (part # 008-9001B in blue of course). I'll let you know after this Saturday!
IMO
Had a set of dualies on my Viper, could not corner worth a
They are only about 25% worn off. Thru them out and put 6" for now while I wait for my bergstromm triple points.
Have the Berstromm's on my sx with ski savers and shims and no darting issues with awesome cornering capabilities on the twisty trails
Thanks for the advice guys, it made a huge difference! I rode it pretty hard today and am happy with the way it handled. The only thing that concerned me was that it was too loose in the back end, I talked to a few others and they all said that their machines were doing the same thing, just the trail conditions.
Cool,,yes that would work allot better for sure,,sign me up too!!!!!!!JERSEYJOE said:I Am Working On A New Approach To The Shimming Idea. I Am Making Some Tapered Aluminum Wedges That Will Go Between The Ski And The Rubber. Sort Of Like Caster Shims For Solid Axle Trucks. I Am Making Various Tapers. They Will Apply Even Pressure Over The Entire Rubber And It Willnot Crush. The Rubbers On My Apex Crushed And The Shim Was Reduced To Nothing. If They Work I Will Have Lots Of Them To Give Out.
RIVERRUNNER
Ill take a set too......Let me know joe!!
JERSEYJOE
Ski Shims
Guys Remind Me Next Week. I Will Be Testing. If All Goes Well I Should Have Them In A Few Weeks. Ends The Problem Of The Ski Rubber Getting Squashed.
I used the Berstrom shim kit on my Viper and it made a big difference. I had a little darting before and all of it is gone with the shim kit.
ALLSEASONRIDER
I fabricated aluminum shims and it worked GREAT on my SX-R. Much less darting in the U.P. last week!!
Hey Joe any updates??????JERSEYJOE said:I Am Working On A New Approach To The Shimming Idea. I Am Making Some Tapered Aluminum Wedges That Will Go Between The Ski And The Rubber.
Yama49601
Silver Bullet
JerseyJoe! I'm interested in a set as well. I would like to try shims before going to the extent of duals. I have suffered from darting - I think. I've never known any different just delt with it. Anyone got any pictures of their shims for me to look at? Thanks - I love this place
Silver Bullet
Silver Bullet
i have a set out now i did for a friend,,will post a pic tomorrow,it's not aSilver Bullet said:Anyone got any pictures of their shims for me to look at? Thanks - I love this place
Silver Bullet
wedge but some aluminum stock i had in the shop i cut up..i made it bigger
so it has more contact area on the rubber bumper.
journeyman
I made a set of shims last night in our machine shop. I used some lexan scraps we had. I made one set at 3/16" and another at 1/4". I put on a new set of Woody's trailblazer 6" carbides today and ended up shimming the front of the rubbers with the 3/16" shims, glue and some zinc coated screws. All of my wear was at the rear of my old carbides. Hopefully I am close to the 60/40% the Bergstrom article says to be at. Before the front of my runners sat above the floor. It looks like things are a bit more level now.We'll see.
i used some epoxy type glue with a stainless screw,works good.Silver Bullet said:Anyone got any pictures of their shims for me to look at? Silver Bullet
he's here,,gota go put 'em on his sled now...........
journeyman
Nice photos, are the shims stainless? Otherwise they might rust.
