horkn
might
those modular type helmets are not that good in motorcycle crashes, neither are open face fwiw. snow shouldn't be any different, although snow is usually softer than pavement, the trees are the same, and more common for sledders.
You can't do sportbike track days with open, or modular helmets, so that should tell you a little something.
if/ when modular snow helmets are both snell and DOT rated, I might go to one, but I like my MX helmet.
Dnrtheil said:Try adding a 1" tall piece of window tint to the top edge of your shield. Works for me, if the sun is too bright a times. Just lower your chin to block the light. Auto tinting goggles work well also. I have always wondered how those hinged helmets would hold up in a crash.
