shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
I do not know for sure but my hunch is that it's because the Viper's have ALOT of midrange timing. Holding them in the midrange too much is probably causing excessive heat and leading to detonation. 2 stroke motors are sensitive to heat and detonation.
Hard to say what happen then,if jetting AND wash was checked? then
bad fuel could be the culprit,just because the pump said premium doesn't
mean is was good stuff with no water..
post pics of the piston..
fasttoys17
what i have concluded and gathered thru all of this is
1. vipers you have to RIDE them no cruising down the trail.
2. i would bump the needle up one notch on cylinder 2
3. I talked to SRXSPEC and he said to use srx lower gasket under the jugs on a viper, for some reason the port opening is bigger for the coolant passage. from the way it sounds with my sled is the #2 cylinder got to hot and cooked it self. sorry IMO viper is just not a womens sled
Mac
Everyone take a deep breath and step away from the motor.
Am I seeing things and could those pistons be intalled backwards? Do I see the ends of the rings? I can't tell but is that the intake hole on the piston facing the exhaust direction?
I noticed that to mac...
Also do you have the rear cooler installed?
cacsrx1
Spring snow in the Hills pulls HARD, you need a lot of fuel to keep things cooled off. On a warm day with soft wet snow my egt's will run ATLEAST 100 degrees hotter in the midrange vs. a 15 degree day in powder. Crusing for miles on the needles up hills on the trails, most people dont know how close they are to a meltdown. Your jetting might be perfect on a flat section at elevation. Now check the plugs and wash on a half mile uphill section in some wet snow.....you might poop.
fasttoys17
no rear heat exchanger and this was the first time that i know of the my motor ever being opened
Get a rear cooler on her,that might have help this issue,heat causes
detonation so the cooler you can have the motor the better..
and what cacsrx1 said too...
journeyman
Just curious fasttoys17........how many miles are on the Viper?
BTW, torque the clutch on at 80ft. lbs.......then loosen up again and re-torque to 43 ft. lbs. That's Yamaha's spec on the Viper primary.
ExpertXViper
fasttoys17 said:I talked to SRXSPEC and he said to use srx lower gasket under the jugs on a viper, for some reason the port opening is bigger for the coolant passage.
I dont know if your getting the 2 gaskets mixed around but the coolant passages on a SRX base gasket are smaller slowing the coolant down. Which causes the coolant to take more heat along with it. Coolant passages are larger on a Viper base gasket.
fasttoys17
journeyman said:Just curious fasttoys17........how many miles are on the Viper?
2200 miles and thanks for the heads up on the torque spec
fasttoys17
ExpertXViper said:I dont know if your getting the 2 gaskets mixed around but the coolant passages on a SRX base gasket are smaller slowing the coolant down. Which causes the coolant to take more heat along with it. Coolant passages are larger on a Viper base gasket.
ill have to double check, i was told to use SRX gaskets
ExpertXViper
fasttoys17 said:ill have to double check, i was told to use SRX gaskets
As you should, I was just letting you know that you had your info mixed around with the coolant passage size from a Viper(Larger) and SRX(Smaller) and the reason why Spec told you to do so.....I have one installed on my stock Viper right now, put it on when I was thinking of running pipes but went back to stock cause I like riding alot more than tuning the clutchs and jetting.
SRX Coolant Passages:
PTO: .787" x .358"
MID: .591" x .358"
MAG: .591" x .358"
Viper Coolant Passages:
PTO: 1.259" x .358"
MID: .432" x .358"
MAG: .591" x .358"
The SRX base gasket evens out the coolant flow and will keep the middle & mag cylinders cooler as it does not allow all the coolant to take the easiest path (which is the PTO cylinder on the Viper base gasket).
PTO: .787" x .358"
MID: .591" x .358"
MAG: .591" x .358"
PTO: 1.259" x .358"
MID: .432" x .358"
MAG: .591" x .358"
fasttoys17
now the big debate is to rebuild or not
I would give it a shot,it's the end of the season here maybe you canfasttoys17 said:now the big debate is to rebuild or not
score some cheap parts..
rx1mtnman
Srxspec said:SRX Coolant Passages:
PTO: .787" x .358"
MID: .591" x .358"
MAG: .591" x .358"
PTO: 1.259" x .358"
MID: .432" x .358"
MAG: .591" x .358"
Question Why did Yamaha change these gaskets? Was the PTO Cylinder overheating ?
Skidooslayer687
i believe the coolant flow is different on a viper then it is on an srx.... It allows you to run the same jets all across
shortstop20
- Mar 6, 2005
The lower compression on the PTO cylinder is what allows you to run the same main jets on all cylinders on a Viper.
fasttoys17
Stevie Ray said:Hey just to let you know this same thing happened to me and it was an engine bearing in the middle right side. There's only one way to find out for sure though......Tear it down....Good Luck
took it apart today BAM we have a winner cyl 2 bearing
