1995 Vmax 600 Twin - Chain Case?
xsivhp
Eau Claire, WI
Hi - Swapped a track on a buddy's sled and during reassembly I noticed there is about a 1/4" of space at the end of the shaft between the spacer and the washer behind the bolt that holds it on (with the 37 tooth gear pushed back into the chain case) - does that seem right? Everything else seemed to go well. :confused:
Thanks,
xsivhp
i just had mine apart and had to loosen the lock collar on the speedo side and tapped the shaft in with a rubber mallet. the shaft should bottom against the chaincase bearing.
If you're talking about your 99 it is a different setup. Is that the case? How are the trails by you? I was thinking about heading that way tomorrow.
Thanks for the reply!
xsivhp
sorry i didnt notice the year. we were out grooming wednesday night and the trails look great. i got all my stuff switched over to the frame i got through you,it worked out really well. thanks again!
That is correct, on that sled, if you have the correct parts in it the lower gear will float. On that chassis the drive axle is captured on the speedo side, on trailing arm sleds it is captured by the bottom gear.
Thanks 800! I can sleep tonight! :)
xs
Good to hear that worked out - I wish you would have got a hold of me 3 days earlier! : )
