What year is this from
braindead1684
Near Flint Michigan
Can anyone tell me what year and make this bottom end is out of and if the crank is the same as the 94-96 600 Vmax.
Should be a serial # somplace on it,mag side by water pump belt housing,
looks like the older twin vm case '94-96...
need a vin to tell ya what year
it was suppose to be from a 94 vmax 600. I am not at home right now so i can't look but i will check for the number when i get home. what should i look for on the serial number to know what its from.
the block appears longer but i think the crank is the same length, still haven't look at the cases for the numbers. The bearing are different and we don't need cases his cases are fine its just a matter of pressing the bearings from one of the 2 cranks we have onto this one if they are identical otherwise.
That is definately a 97-98 twin case, it does not have the seperate water pump/recoil housing. The cases are different, as well as the crank.
braindead1684 said:
8cr0001 y1 is the case no
From what i found out that case could be a 500 or 600(were the same) '97
to '01 v-Max,,if we knew what cc it was that would narrow down the years
because they only made the 600 3 years, '97-'99,,the 500 went a few more
years till '01..
so yea it's the newer vm case...
Sorry I'm late to view this post. Ya that looks an awful lot like the case of an '97+ motor. Spent a lot of time looking at that case.
Sorry for it not working out the way you had planned.
Dave, Why is the bottom of you '94 block so shiny?
Because i sanded it down smooth then primed,painted, and clear coated the whole block.
Except the jugs....they were glass bead blasted.
