pup55
886 ft
trypup55 said:Main 152.5
Pilot #50
Jet needle 8CFY7-55-2
Valve seat 1.5
Everything is factory set.
?????pup55 said:Thanks. When you have time i would like to talk about the carb problem.
Check your jetting in that range(kill motor pull plugs)Twin_SXs said:any resolution here? My sled is running terrible in mid-range. Runs great both at off-idle and WOT... Bogging down hard in midrange--right where you like to run at 40-50 Mph... Would love to know what you did to resolve it.
run your sled in mid when it acts up blip your choke if it comes out of itTwin_SXs said:Okay, I'll do that. But let's assume it's rich...Cause that's what it feels like--like it's flooding out as you try to cruise along at 35-40. Give it hard gas and it comes out of it. So, if it's rich in that range, what should I do to fix it?
