viper powervalves put in upside down?
Vector88
Labrador, CANADA
this mite be a stupid question but i forgot which way my powervalves goes in. better to know than to be sorry! i attached 2 pictures! tell me if the first picture is right or the second is right! thanks
really? the second pic looks like the right way to me and i have a spare block and im rying it out on that and it fits great in the groove inside! well i guess your right and have alot of experience with this!
well if u put your finger in the cylinder exhaust port .. and pull the power valve gently open u will see that the exhaust will be flush with the power valve....
I just cleaned mine today, Man what a differance in the way the sled runs !!!
way more responsive. :rockon:
(I know you already got your answer but pic 1 is correct way)
jeepers creepers daman...now you are scaring me.Can't remember if mine are the right way or not.Could be the solution to all my problems.But I am sure mine are right.Got me thinking now...damn...have to go check them I guess.
rx-1mountain said:
lol...thanks for the info!
Tip for cleaning them...let them sit in bowl of seafoam overnight...then just take a utility knife scrap gently & wipe off...real easy...
what oil are you running?
Another tip is run 2oz of seafoam in your fuel (full tank) & 2oz in your oil (full tank) & you will notice that they stay a lot cleaner...cheers
SeaFoam
Just a note on the Seafoam. IT WORKS !!! If you use it as stated above ^^ regardless of the oil used your rings and power valves will remain free and clean. The stuff works if you use it often. Carbon SUCKS !!
