Torque spec
SRXGTO67
NW IL.
Installing my Primary clutch on my 98 srx700 Per Yamaha manual lube bolt & torque to 85ft lb I have read other posts stating after torque to 85ft lb loosen & retorque to 45ft lb, the manual dosnt have that step. what is correct?? Thanks
Tightening steps:
1.Tighten the bolt to a torque of 120 Nm (12 m • kg, 85 ft • lb).
2.Loosen the bolt completely.
3.Retighten the bolt to a torque of 60 Nm (6.0 m • kg, 43 ft • lb).
