what are you guys running for a belt on the srx? mine has an 38x4420 xtreme(gates) belt on and has an yamaha 89L-17641-01 in the holder.
That sled should have come from the factory setup for an 8DN. The 8DN is a very hard belt which requires more side pressure, but is very durable. It is a very good belt for the higher powered Yamaha sleds with stock clutches.
Unless your clutches have been adjusted to work with the other belts, then your setup is likely off while running those belts. The 89L is a softer compund and is used on the lower powered Yamaha sleds. I didn't bother to look up the specs on the Gates belt, but it is likely a softer compound as well.
Personally I like the 8DN for most setups on stock Yamahas. If you need more adhesion for a specific setup, then you might consider another belt. Just be sure that you match the setup to the belt.
Full part Number : 8DN-17641-00-00
YAMMIEGOD3:16
TAKE THEM TWO BELTS FROM YOUR CLUTCH HOLDER AND SLED TO A HOOK ON YOUR GARAGE WALL. RUN THE 8DN BELT. AND DON,T LISTEN TO ANYTHING ELSE ABOUT HOW GREAT THOSE BELTS ARE. 3:16 (yammie tony)
Skidooslayer687
yeppers, I agree 100%, run the stocker
so this runs the same belt as an apex. so whats a good price for one of these and any suggestions to where to find any reasonable thanks for the input.
YAMMIEGOD3:16
THAT BELT IS AS COMON AS SLICED BREAD. ANYWHERE THAT SELLS YAMAHA SNOWMOBILES WILL HAVE THEM. I HAVE SEEN THEM FROM $48 TO $53. WELL WORTH IT. 3:16 (yammie tony)
Skidooslayer687
YAMMIEGOD where do you get your belts for that price?? I've been paying like $120 for a belt from the dealership up her, but I dont really have any other options that I know about to purchase a stock belt other then from the dealership
You can go on Ronnies.com and buy for $60.67 plus shipping.
i just bought one ebay fpr $62.00 shipped so i guess i wont have to look anymow. thanks.
YAMMIEGOD3:16
LOCAL DEALER !! 3:16 (yammie tony)
if its anything like a cover price or clutch parts the local dealer would alot more for the belt then what i just payed for it.YAMMIEGOD3:16 said:LOCAL DEALER !! 3:16 (yammie tony)
Port Yamaha - $55.40
marty f
belt test
tested aftermarket belts against the 8dn and it was the better belt of all others so stick to stock belts!!!!!!!!!!!!!!!!!
ya i got it a couple of days ago. was suprised its a top groove belt. but better for cooling i guess. thanks guys.
what is the stock rpm clutch engagement and how high in the secondary is the belt should be above? i was thinking like 1/16" maybe. (yea i know its suppose to be in MM's lol.
mod-it
Stock engagement is 3800.
1/16 should be fine, I usually set mine between 1/16 - 1/8. Much higher than an 1/8 and it squeals and drive me nuts.
I like to jack the track off the ground and set it that way. At idle the track should slowly spin, turn with jerky movement, or be able to spin with slight help from you.
