Yamidude59
when i buy the br9ecs plugs do they come with the correct gap? or does that need to be set?
patsxr700
yeah they all come with the rigth gap.. sometime they fall on the floor and it can bent the gap and it may not fire right.. the 9 stands for how big the gap is..
yeah the br9ecs are recommended not to be re-gapped. I read about it before around this site.
br9es and others are ok though, if memory surves me right. to be re-gapped.
the 9 stands for the heat range of the plug not the gap.
and sometimes they are dropped in shipping and what not so you have to check the Gap. Only Plugs you do NOT Gap are Iridium plugs.
Lower the number, Hotter the plug.
NYsledneck
And there are 2 different gap sizes on br9ecs plugs so be sure to get the right ones. Can`t recall the correct part # but it has been talked about on here plenty.
ExpertXViper
http://www.totallyamaha.net/forums/showthread.php?t=34241&highlight=br9ecs
Click the link and itll have the part #s you need. BR9ECS shouldnt be regapped, you can measure them to check em but I wouldnt sit there and bend that electrode back and forth, the electrode isnt casted to the rest of the plug its welded.
Skidooslayer687
there is 2 different ones you can get, if i remember correctly ski-doo uses the plugs in some of there machines with the different gap
DV8 said:and sometimes they are dropped in shipping and what not so you have to check the Gap. Only Plugs you do NOT Gap are Iridium plugs.
the electrodes are laser welded and if re-gapped it will weaken them. also mentioned in the link expertXviper put in.
Danger Dog
Skidoo uses them also they are gapped at .018 yamaha at .028. I prefer the .018 myself. That is what I run in my prostock and stock srx.
OZ_872
I always check my gap before installing a new spark plug, 90% of the time the gap is right but I feel better knowing I checked.
SRX-SKI said:the electrodes are laser welded and if re-gapped it will weaken them. also mentioned in the link expertXviper put in.
Yes it is welded, But if I open a new one and the gap is incorrect I will adjust it. No, you dont keep moving it, or you will have a problem.
Yes, I was just making sure it was understood.
