PhatboyC
My power valves where all cleaned by the previous owner before ridding last winter. I did approx. 2000km (1243 miles) last winter.
After removing my first power valve I though I was in the clear. It just slip right out and just needed a towel to wipe it clean. My surprise came with the middle one. The cable pull through but, here is the twist, the valve itself still slide right out and was just as clean. The last one was about half way about to pull through.
I was doing this on a cold engine that hasn't been started this season yet. The valves where covered in fogging oil. Could the fogging oil break down carbon deposit? If not then it sure help getting them all slippery. But why did it pull through if they weren't hard to pull in the first place?
Here's is what I'm thinking. Since these valves had been sent to a welder to fix the pull through years past. The filler the welder used gradually soften over the years. Even if they didn't seized last winter in didn't take much. Make sense?
Fist one, very slippery.
Clean enough without any wiping I think.
Far right is the pull through. Middle is the one about to. Left is intact.
This is after a quick wipe down. No cleaner yet. Strangely enough the dirtiest one was the one that was intact...
This is the cable of the "about to pull" valve. Should I buy a new cable?
